Check engine
Old May 7, 2024 | 04:43 PM
Jacobmccannell's Avatar
Check engine
1984 Camaro with a carb swapped 350 tbi my question is the check engine light stays illuminated and obviously the car is running great! My question is there a way I can make this light work as a warning light like it was intended? I'm not sure what the connection looks like but it's not attached to anything so I would assume that's why the light is always illuminated
I believe this is run by the the ECM any help would be greatly appreciated
Old May 7, 2024 | 05:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Check engine
Is there a lamp driver module right now independent from the ecm ?
Old May 8, 2024 | 03:13 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Check engine
I just wrote out a post - that honestly didn't apply to what you have.
If your running Carb Swapped TBI than your obviously not using an ECM. This diagram shows how your 84 dash harness and Light Driver Module operates.
Since you ado not have a factory Carb, I'm guessing that you also don't have a factory distributor and you also probably don't have any factory emissions. Since those are most of the things the ECM checks,.... what exactly do you want the CHECK ENGINE light to report to you ??
Old May 8, 2024 | 05:19 PM
Re: Check engine
All im looking for is oil pressure engine temp and maybe battery voltage not sure if that would even apply with these!
Old May 8, 2024 | 05:21 PM
Re: Check engine
And yes I'm running a hei distributor and all emissions have been removed
Old May 9, 2024 | 12:13 PM
John in RI's Avatar
Re: Check engine
Nope,...
You'll need to deal with the C100 firewall connector on the drivers side for that stuff. Here Ya' go:
https://berlinetta.info/C100.htm
84Recarotrans
Feb 24, 2011 03:49 PM
ranger77
Sep 7, 2009 09:57 PM
stig
Apr 23, 2009 12:22 PM
sleeper84
Apr 2, 2007 09:05 PM
