automatic up/down windows???
Old Jan 25, 2002 | 02:12 PM
nosaint's Avatar
Car: 1986 Trans Am
Where are the controls held for the auto window feature?
If I use a fourth gen switch will it auto roll up/down my window or is it in the motor or some where else completely????
Old Jan 25, 2002 | 10:04 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
BCM(Body Control Module).Don't have one in our cars.
Old Jan 25, 2002 | 11:36 PM
nosaint's Avatar
Car: 1986 Trans Am
Thanks, gonna be putting on my fourth gen door panels this summer and I would very much like to have that option. What does this part look like? and how hard do you think it would be to slap it in somewhere??
Old Jan 26, 2002 | 06:11 PM
RSpeed's Avatar
Well,you can get one from Directed Electronics Incorporated(DEI). They make one that automates existing power windows. Check at your local stereo/alarm shop.They should be able to get you one and install if needed.This would a lot easier than integrating the factory module.
Old Feb 6, 2002 | 10:59 PM
FiReBReTHa's Avatar
RS Speed
your a stud, with lots of respect from me,
DEI is the way to go,
drivers side roll up down.
pass side roll up down...
careful, dont let pets hang out, and accidently hit button, seriously, one time while driving, lol.....loll.... your gonna laugh...
driving down town, me and two friends, driving... then bam, diablo... well, three heads popping out pass side window.... lol, it was a sight, "inside! inside!"
be safe.
Old Feb 6, 2002 | 11:27 PM
RSpeed's Avatar
:sillylol: That is funny.
Old Feb 7, 2002 | 12:31 AM
2vmodular's Avatar
DEI530T window modules will add "one touch" up and "one touch" down to both windows in your bird. Tap the down button, and the window will roll down fully and stop, same with the up button.
DEI window modules work on current sensing to determine when window is rolled fully up or down. When a window motor stalls at the end of the window travel range, the electric motor draws considerably more current than when the window is still moving. One touch down is safe, but one touch up can be difficult to calibrate so that it won't amputate a childs finger but at the same time has enough power to move an iced over window in the winter time.
As for sources, there's the local car audio shop, ebay, and places such as www.autotoys.com
If you just want one touch down, you can grab the one touch window module out of a ford. The window motors work on the same wiring system, ground at rest, reverse polarity. Old chevy motors draw a little bit more current than newer fords, so you may have to swap a couple resistors.
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
