lights switch
lights switch
I have a prblem with dash lights, when I turn on the lights in the console (tach speedo etc) tach and voltage meters are dead and right green arrow (turning light) turns on but turnign light out side the car doesnt come on. when I turn off the dashlights the problem is gone.
I believe its some short circuit in the part of the switch which adjusts the "power" of dash light.
How to remove the head light swith? or maybe the problem is smoewhere else?
My car did the same thing. Turned out to be the aftermarket radio was grounding out on the dash and blowing the ACC fuse. All that stuff goes thru the ACC fuse on mine. Also, make sure you have the proper bulbs in the turn signals...1157 I believe and make sure all the bulbs are good or the signals won't blink. On mine that includes the side marker lights. Good Luck!
Pilotrick50
Sep 2, 2015 12:48 PM
