firebird headlight door issues . . .
Old Feb 3, 2002 | 10:21 PM
RoadRacer's Avatar
Ok, I'm almost out of electrical issues, I swear!
The headlights on my '87 GTA light up, but the doors won't always open. Every now and then they will randomly work, but it's never a sure thing. If I crank them up by hand, they will lower themselves automatically when I turn the lights off, but not go up again!
Also, though it might not be related, the pass. side light motor runs for a few seconds every time I turn the power on to the car. Even when the light switch is "off"
Any clues about his one?????
Thanks,
Don
Old Feb 3, 2002 | 11:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
A pretty common problem that's starting to happen due to the senior age our cars are getting. it's been discussed alot here if you do a search on it.
Here's the most recent topic about it..
https://www.thirdgen.org/techbb2/sho...threadid=13618
Unfortunaly, it seems Steve's website is down (I think he's rediong it or something). he had a good tech article about rebuilding them but, you can get a general idea of what's going on by reading the post anyways.
One of these days I've got to redo both of mine as well.
Old Feb 8, 2002 | 01:47 PM
Fade00's Avatar
My drivers side headlight motor was doing what you described: not going up, but going down after being manually cranked. I went to a junkyard and replaced the motor.... It's a pain because you have to take the whole headlight assembly out and the bolts are not exactly easy to get to. Also when I put the assembly back in it wouldnt go up because it was hitting the hood.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
BlackTopKing
Aug 19, 2015 12:13 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
