Tach not working after carb swap
Old Feb 11, 2002 | 03:06 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Well here is what i have done........I swaped out my TBI for a Carb. I used the Proform HEI with Vac advance. I also have a MSD box and used the 3 pin connector. The car runs fine however the tach is just dead. I have the white Tach wire plugged in to the Tach pin on the dist. but still noting on my dist ther are 5 pins 3 in the back where the MSD jumper and + and Tach pins in front.
ANy Ideas
Brian
Old Feb 11, 2002 | 10:20 PM
colincamaro's Avatar
sounds like a bad ground
Old Feb 11, 2002 | 10:47 PM
Matt86Z's Avatar
If the tach's floating, it's the ground strap.
Old Feb 12, 2002 | 06:24 AM
I am not getting any movement at all..........With the MSD Harness they have no power going to the + side of the coil is this correct?
Brian
Old Feb 12, 2002 | 01:49 PM
Got it fixed............when using the MSD you must us the tach output on the MSD box. Hey I learned something new.
Brian
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
