Fuel Gage
Fuel Gage
Fuel Gage reads above fulll all the time. When I jumper the pink wire to ground at c200 and c315 connectors, in both cases it starts toward empty, but not all the way. slows down at 1/4 tank or so. I know there is more than a 1/4 tank, but I also know it isn't above full... any ideas.?
This is one of the last little things after doing the TPI conversion.
Car: 89 RS
Transmission: TH350
TPI conversion? TPI to CARB, or vice versa?
When I bought my car, (which was a 5.0l TPI, that had been converted to a 5.7l Carb set up) I found underneath that the plug in the bottom of the gas tank was unpluged. Pluged back in the gauge worked fine up until 1/4 of a tank, then it never got lower. Kind of half ***, well a quarter ***, geez.
Well after I needed a new tach (never worked), I went to a junk yard and found a 5.0l carbed camaro, swiped all the gauges and replaced them, since then fuel gauge has worked fine. Coincidence, I dont know.
My .02
My .02
92camaroJoe
Aug 13, 2015 06:07 AM
