Replacing my Ignition Help
Old Mar 18, 2002 | 05:15 PM
BLUEIROC5.7's Avatar
Hey all i got a 89 iroc 350. I dont know what to do . I have pulled the wheel off. Then i dont know what to do. Also my old key came with the chip in it. The new one does not .The man at the chevy lot said i dont need that. There is a whire that will fix that. thanks for the help
Old Mar 19, 2002 | 02:58 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Do a search for VATS.. it comes up every once in awhile. If you're needing to disable VATS, I believe you'll have to email the people that know about it. For obvious reasons, the fix isn't really put on public display.
Old Mar 19, 2002 | 04:40 PM
The security light did not come on. The key gets to the start position and then is stuck
Old Mar 19, 2002 | 06:14 PM
deadbird's Avatar
Engine: TPI 305/ v6
Stuck as in like, turns to the 'run' positin but, won't turn to enough to be able crank the car ?
It could be a problem with the ignition switch itself being broke if so (they are seperate from each other & there is a rod that connects them). I had that problem when I pulled my shifter out of gear one night (it took no effort to do) There is a cable that attaches from the shfter to the ignition switch that locks out the shifter when the car is off. I solved mine by hacking the cable off & replacing the switch (since I broke it fully using vise-grips to start the car).
Of course, your sitiation could be something completely different and what I said has no meaning to your problem ( which wouldn't be a first )
justin57
Aug 20, 2015 07:05 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
