Fuel Pump Diagnosis
Fuel Pump Diagnosis
I'm trying to determine if the fuel pump is out in my '87 IROC. I tested the relay and fuse and both were ok. However, when probing terminal G with a test light, I don't get power when I turn the key. (not even the two seconds). I also powered 12v to the terminal to engage the pump, but got nothing. Any ideas?
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Sounds like a bad pump.Try giving 12volts to the gray wire behind the back seat that goes through the wall into the tank.(If I remember right it is gray).That should turn the pump on if it is still good.
92camaroJoe
Aug 13, 2015 06:07 AM
