FS: CenterForce flywheel and dual friction clutch..NEW!!
Old May 31, 2006 | 06:35 AM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
These are some high dollar pieces and I need to get rid of them..they are both BRAND NEW never been mounted or used.
The part number for the flywheel is 900120
Centerforce “800” and “900” flywheel part number prefixes designate specially made flywheels from aircraft grade billet aluminum for light weight (low inertia). Centerforce aluminum flywheels also feature mechanically retained starter ring gears as well as replaceable steel friction surfaces that have been heat-treated for abrasion resistance and long life. All Centerforce flywheels are CAD/CAM designed and then CNC machined to strict tolerances for perfect fitment and hassle-free, bolt-in performance.
Heres some info I have on the clutch set...part# DF161911
spline count on clutch is 26 and it measures 10 3/4 inches
10 3/4 disc w/ 10.4" pressure plate bolt pattern..
IF you need pictures just email me at pctec@surry.net...I'll take $600 for both
zman1969
Oct 1, 2015 11:09 AM
mfp189
Sep 27, 2015 09:25 AM
