TPI setup. Cheap
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
TPI setup. Cheap
Pulled from my 1987 Corvette, an actual Corvette TPI Tuned Port Injection setup for 350 cid 5.7 liter engine. Setup comes with intake manifold baseplate, fuel rails, fuel injectors, plenum, runners, throttle body, cast aluminum distributor cover, thermostat housing.
Bonus!! - Included is an aftermarket adjustable fuel pressure regulator (AFPR), and aftermarket aluminum TPI air foil. Great for hot rods, or making your TBI or Crossfire injected car EFI. Included sensors: coolant temp, air temp, EGR.
I have both MAF and MAP sensors available, depending on which harness you go with for your car/street rod. MAF or MAP sensor can be had for small additional fee. I also have electronic HEI distributors, large cap and small cap, which can also be had for a small additional fee.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by droppedbagged72
So how much are you asking. If you give me a killer price I will take it.
I'll pm you.
-- Joe
Car: 1985 Corvette
Engine: TPI
Transmission: 6 speed
Axle/Gears: D44/3.45
You said you had a few extra distributors? I need a coil-in-cap TPI distributor. It would have the older style connection for the 4-pin weatherpack harness.
my email is khasting@charter.net
(yup, I'm just a lurker over here, I mostly post at corvetteforum)
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 1985 Corvette
Engine: TPI
Originally Posted by anesthes
I've got one but no cap and coil. Its electronic controlled but can't tell if the dizzy gear is for roller camshaft or not...
-- Joe
-- Joe
Shipping would be to San Diego, 92122
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
If its a large coil-in-cap unit, just without a coil or cap, that's fine. I can figure the gear out. Does it have the ign module? Let me know where to send payment. I can do paypal or check/mo.
I'm pretty sure they all have ignition modules.
-- Joe
Car: 1985 Corvette
Engine: TPI
anesthes,
Tell me what's going on with this distributor. It's been 2 weeks and I haven't heard from you or received anything. Do you have a tracking number?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
anesthes,
If it got lost it's insured and fully refundable.
-- Joe
evilstuie
Apr 14, 2016 08:52 PM
Sanjay
Aug 12, 2015 03:41 PM
