testing the waters... 195cc AFR Heads
Car: 83 TA
Engine: 5.3
Transmission: 4L60e
I was building up a 383 stroker, but I lost interest in the firebird project. So I'm going to see how much I can get for these heads.
They are the AFR 195cc w/ 74cc chambers and L98 style plugs.
I paid $2100 for them, and would like to get $1800 for them.
Here are the specs:
AFR 195cc SBC Eliminator Street Cylinder Head
The Ultimate Bolt-on Emissions Legal Street Weapon
The AFR Emissions Legal (versions from 1969-94 with heat riser, CARB EO #D-250-2), 195cc intake port small block Chevy cylinder heads are available in your choice of straight or L98 angle plug versions. These heads feature a 74cc or 68cc combustion chamber with a 64cc exhaust port and a 3/4” thick head deck (ideal for nitrous or blower applications). The 68cc chambers are designed for flat top or dished pistons; domed pistons will require additional machining. Standard valves are 2.020 intake and 1.600 exhaust with AFR’s hardened ductile iron interlocking valve seats. The exceptional flow characteristics, ideal operating range of 2000 rpm to 6500 rpm, 23º valve angle, and standard valve spacing make this the perfect street head for 350 cid to 400 cid engines from 1955-86. Available for 1987 to present engines with center bolt valve covers and 2 center intake bolts at 72º angle. No special parts are required. Dual valve cover bolt pattern is standard.
Note:
Hydraulic roller cams typically experience valve float at 5800-6000 rpm because of their fast ramp rates. AFR suggest you upgrade your springs to AFR part #8032, 1.530 O.D. with higher spring pressures and use our Patented “Hydra Rev Kit” to reduce chances of valve float associated with rpm 6000 or higher.
Here are the specs:
Note:
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
