chip burning and tuning equiptment
Old Sep 5, 2006 | 09:57 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
I going to run the Holley 950 commander with my turbo project. I only used the Ostrich 1 time to try it out. the chips have only been unpacked to look at. $240.00 shipped.... thats a savings of over $80
Moates Ostrich (Real Time ECM Emulator) Product Description: This is THE standalone USB emulator. It might be the ONLY one. It will emulate 2732A, 27C128, 27C256, 27C512, and more! Up to 4mbit (29F040) 8-bit emulation. Robust, USB-based realtime EPROM emulation in the palm of your hand! Battery backup lasts 75 years (standard AAA), so you can leave it in the car if you want to. With this device, you can upload an entirely new binary without a hiccup while the car is running. Or, you can change one parameter at a time. Fully compatible with TunerPro RT and TunerCat.
Moates Burn1 (Flash-n-Burn USB-Based Chip Programmer) Product Description: USB Chip Programmer works with the AT29C256, 27SF512, and AM29F040 chips. Self-powered from the USB port, so no power adapter is needed! Burner can also be used to read stock GM memcals using the HDR1 adapter. While it will only program the three types of chips listed, please note that those three chips can be used as drop-in replacements for most EFI applications. Comes with stand-alone chip programming software (available for download). Also compatible with TunerPro RT. Will read most stock-style chips (2732A, 27C128/256/512/etc).
GP1 Package: GM Adapter w/ 2 chipsProduct Description: This package is very popular. It comes with two 27SF512 chips, an 'S2' ZIF socket, and a G1 adapter! This is everything you need for TPI/etc chip adaptation. If you want different chips or different socket, just purchase the pieces separately from the other items listed.
Ray
Attached Thumbnails chip burning and tuning equiptment-gp1-package.jpg   chip burning and tuning equiptment-burn1-flash-n-burn.jpg   chip burning and tuning equiptment-ostrich-emulator.jpg
Old Sep 6, 2006 | 12:21 AM
onesweet92z's Avatar
Car: 92 camaro z28
Engine: 355 tpi
Transmission: t-5
Axle/Gears: 373
Is this everything you would need to burn a custom chip?
Old Sep 6, 2006 | 09:28 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
besides a laptop, and software. With the Ostrich you can make changes of the fly, and once you got it dialed in you can leave it in the car or transfer the tune onto a chip. Plus Craig Moates (the Maker) has great customer service, and tunes that will give you a great starting point.
Ray
Old Sep 6, 2006 | 12:38 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
You have a PM
Old Oct 9, 2006 | 09:05 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I am interested in one or the other but not both. How much for each seperately? (ostrich) or (BURN1 & adapter w/chips)
Thanx, Tom
Old Oct 9, 2006 | 09:15 PM
graphicideas1's Avatar
how much for the burner?
Old Oct 10, 2006 | 03:30 AM
rtkjadams's Avatar
Car: 92 Camaro Z28
sorry guys, all is now sold
F.I. 57 Belair
Aug 23, 2021 01:09 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
Deemax
Sep 12, 2015 06:53 PM
