Come and get this stuff!! Local only, all at once!!!
Old Jan 9, 2007 | 10:47 PM
dakleenupman's Avatar
Car: 2000 Astro
Engine: 4.3L of funk
Yep, that's right, $45.00. And for that money you will get the following items for a 1982-1992 Chevy Camaro/ Firebird and some universal items:
1- 14" factory rally rim with tire, tire no good
2 - TPI TPS(Throttle Position Sensor, check how much at your local auto parts store. $30.00) and Neutral Safety Switch ($17.00)
3 - factory like new front license plate holder for Z-28, IROC or RS
4 - TPI intake boot (slightly shortened)
5 - Used TPI alternator, great for core exchange or for custom rebuild
6 - Passenger side, power mirror with glass and wiring
7 - dome light (complete with wiring harness)
8 - MANY assorted interior trim pieces
9 - rear bumper cover (needs paint and emblem, off Z-28)and rear GFX pieces
10 - factory pullys from crank and alternator, serpentine off TPI motor
11 - power steering caps (2)
12 - master cylinder cap with gasket
13 - 4 halogen headlights with trim surrounds(good shape)
14 - automatic shifter handle assembly
15 - parking brake handle assembly
16 - Grey carpet for rear section, slightly stained, looks good
17 - New outer tie-rod end, never used
18 - TPI factory fuel pressure regulator body(no spring, used), with upper plenum gakets(new)
19 - 85mph speedometer, temperature, voltmeter and fuel guages
20 - factory front speakers with brackets
21 - 6 felt guides for the front windows(hard to find)
22 - lower passenger side cover for under the dash
23 - Black upper section of center console(NO power swithces, perfect for custom install, no armrest)
24 - wiper arms (2)
25 - lower section for TPI intake boxes
26 - miscellaneous relays, wiring, bolts and the such. I am sure I may have missed something.
I want it all gone at ONE time. $45.00 takes it all. PLEASE DO NOT ASK IF I HAVE SOMETHING IN PARTICULAR. This is a one tme deal as I am liquidating any and all Camaro/ Firebird parts that I can no longer use.
I may entertain the idea of delivery as long as it is not too far away from Algonquin area.
I have pics of mostly all. Email and ask and I will send. These items are mostly used with some new ones as well.
Thanks for looking. Contact me at 1----773----744----75---57 with any questions. If I don't answer, leave message.
I HAVE MANY PICS AVAILABLE!!!
Thank you for looking.
Chris
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
xbazzarex
16
Oct 6, 2015 08:42 PM
Clint307
Sep 23, 2015 07:16 PM
