everythings gotta go,gears,ignition, 350
Car: 91 camaro rs
Transmission: t5
going to a ls1 so its all gotta go, located in rochester, ny
-complete tpi set up, new maf, harness, ecm, stock penum, base, runners, distributer, gasket matched, 19lbs injectors- $350
-jacobs master mind nitrous controller one side piece is broken-$75
-jacobs fc2000 ignition box and pick up-$100
-86 700r4 with stock converter 68kmi $300 pick up only
-black 16x8 crosslace wheels with good tires- $200 perfer not to ship
-bbk billet underdrive pulleys 3pc like new 86-87 $100
-edelbrock hi flo tpi base untouched -$250
-dell latitude laptop newer battery , power cord has parellel port- $250
-67-69 camaro hooker super comps some dents for clearance$50
-010 350 2bolt std bore $100- pick up only
-91 305 roller shot block new rings bearings -$50 pick up only
-mr gasket street runner chip 86 305tpi auto-$15
-3.27 borg gears $75
-2.77 borg gears and posi $75
-2 series borg carrier, supposed good- $25
-ford red top 30lb injectors $100
- lt1 injectors-$50
- schwitzzer s3 turbo $50
i can get pics, some can be seen at http://www.cardomain.com/ride/236894...m/ride/2368942 or email me at smokin91rs@yahoo.com im open for offers and questions, thank you-Gary
- lt1 injectors-$50
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
do you still have the tpi setup? is everything there? i want to swap a tbi to tpi. if so how much to ship to 68113?
Zachattack0925
Aug 12, 2015 09:52 PM
