Built 355
Old Mar 18, 2007 | 11:41 AM
irocz2173's Avatar
Car: 1987 5 speed Iroc-z
Engine: 305 TPI (not for long)
Transmission: 5 Speed
Built 355
up for sale is my built 355, only has about 100 miles on the rebuild, if that...minimal runtime
Motor consists of:
1989 Corvette 350 2 Bolt Block - bored .030 over making it a 355
Corvette 113 Aluminum Heads - Ported
New Pistons/Rings and rods
Crank Turned .010"
New Crank/Cam Bearings
High Volume Oil Pump
High Flow Water Pump
Comp Cam 276HR - 224/230 Duration at .050"...503/.510 Lift
Heads:
New Manley High Lift Valves - Single grove on top of the valve allows for more lift
Comp Cams 1.450 Daul Springs - bored spring pockets
Shaved To Approx. 9.8 to 1 Compression
Port Job
Crane Energizer Roller Tipped Rockers 1.6 Ratio..Making Lift .536/.543 approximately
its a very stout motor yet streetable, my engine builder said its capable of 400 horse all though it was never dynoed, definately will get a car into 12's with the right suspension mods. Comes with all the accesories if you want them. Power steering, waterpump, altenator, starter. This motor would be perfect for an HSR buldup or a very stout TPI.
asking $2500 for the long block with all the accessories
I also have many other SBC parts. Let me know what you need. I have a Powerdyne supercharger kit also but it is for a mustang but I have been told it can be adapted to fit a chevy very easily. Very nice supercharger never used. I am asking $3000 for it. I received it in a trade but now i really just need the money. i also have 26lb accel injectors with the same amount of runtime as the motor would like to get $200 for them.
Matt
201-312-5446
Northern New Jersey
Old Mar 19, 2007 | 11:57 AM
irocz2173's Avatar
ttt
Old Mar 19, 2007 | 07:51 PM
dcboyz4eva's Avatar
Car: 01 gti, and 89 irocz
Engine: 355cu
Axle/Gears: 373
if you didnt sell the long block would you part it and sell me the short block? and if so how much im near reading pa so im not too far
Old Mar 19, 2007 | 09:45 PM
irocz2173's Avatar
If you want the shortblock it is yours. I have had a lot of requests for the heads but i wouldn't part it out that far without someone that was interested in the shortblock. I would need to get $1700 for it so let me know.
irocz2173's Avatar
Old Mar 21, 2007 | 06:12 PM
irocz2173's Avatar
Re: Built 355
ttt
Old Mar 25, 2007 | 05:27 PM
irocz2173's Avatar
Re: Built 355
ttt
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
6998poncho
Sep 25, 2015 02:56 PM
