nitrous system, gauges, etc for sale
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Performance parts, etc for sale
1- Edlebrock nitrous purge kit for 6 AN line
Part number is EDL-72178 and retails for $106 from summit racing. I am selling mine which has been used for a year for $85
1- Edelbrock dual stage nitrous kit. This kit is called the Performer RPM II Dual-Stage kit. The part number of this is edl-70082 in summit racing. New this lists for $750 I am selling it for $675 with the bottle (half filled approx), brackets, solenoids, fuel pressure safety switch etc. The only thing missing is one set of jets for the 150 shot on the first stage which cost about $8 to obtain. This kit was used for a year and the second stage was NEVER even activated. The plate for this has had 2 additional holes drilled into it so it would fit my edelbrock pro flo EFI system, this in no way affects the function or sealing capabilities of the plate.
Mallory Comp 110 fuel pump and Mallory 3 port return style fuel pressure regulator. This was used for the nitrous fuel system for the above kit. These parts have less then 5 hours on them total since they were only activated at the strip. The part numbers for these are MAA-4110 (pump) and also MAA-4309 (reg) in summit racing. These retail for $242 new in summit, I am asking $200 for both.
Autometer PRO COMP fuel pressure gauge and gauge pod. The gauge is 2 5/8” and is mechanical. Pressure reads from 0-15 PSI ATM-5411 is the part number from summit. I am asking $45 with the gauge pod. This gauge is in excellent shape with no scratches, etc.
Autometer PRO COMP fuel pressure gauge and gauge pod. The gauge is 2 5/8” and is mechanical. Pressure reads from 0-100 PSI ATM-5412 is the part number from summit. I am asking $45 with the gauge pod. This gauge is in excellent shape with no scratches, etc.
Case of royal purple SAE50 oil $40
email me if interested camaroracer1992@yahoo.com
colton_carlson
Mar 8, 2019 12:21 PM
9192camaro
16
Feb 3, 2019 12:21 AM
