1985 tpi
Old Apr 24, 2007 | 02:53 PM
patsy1's Avatar
1985 tpi
i have a 1985 camaro under dash harness engine bay harness tpi set up with 19lbs injectors computer everything u need to change over most of the sensors MAF and its even good. also have a perfect set of split rear seats
Old Apr 27, 2007 | 10:10 AM
emac2001's Avatar
Car: 86 z28
Re: 1985 tpi
how much. this is including everything to convert a carbd car correct
Old Apr 27, 2007 | 10:52 AM
patsy1's Avatar
Re: 1985 tpi
yea everything is here minus the brackets and throttle cable and detent for the tranny 85 is its only year cause of the burn off relay for the MAF like i said mostly everything is this there u might have to by few more sensors gaskets that kinda stuff but i have 550 in everything ill let it go for $400 shipped i can get pic if need be let me know or call me with ?s 412 512 3315
Old Jul 25, 2007 | 02:37 PM
1988350bia's Avatar
Car: 1988 camaro SC
Engine: 355 four bolt
Transmission: th350
Re: 1985 tpi
how much for the ecm shipped?
camaroracer305@aol.com
Old Mar 2, 2008 | 11:28 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: 1985 tpi
Any chance you'de seperate the mAF?
Old Mar 17, 2008 | 10:34 AM
RedBravo's Avatar
Car: 85 TA
Transmission: LB9
Axle/Gears: 9.5:1 3.23
Re: 1985 tpi
Hi. Do you know if putting an 86 MAF sensor in an 85 would hurt anything? I read that you said there is a burn off relay on the 85 but I do not know what all that means. Others have told me it's not really a big deal. Thanks.
Brandon
usafirebird
Exterior Parts for Sale
Oct 19, 2017 02:00 PM
Ducati900ss
Sep 2, 2015 09:05 AM
Thornburg
Aug 27, 2015 11:34 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
