HEI distributor
Old Apr 26, 2007 | 04:44 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
HEI distributor
this distributor came with the crate engine i bought in late 04, but i have never used it. it has been sitting inside ever since then just colecting a little bit of dust.
the description from the GM site is as follows:
This distrbutor has the melonized cam drive gear P/N 10456413 for steel roller camshafts. This distributor is required on all crate engines and roller camshafts that are made of steel. If engines are assembled not using this gear, it may affect your engine warranty. Use connector wire P/N 8917052 to ignition. Used with all small and big-block V8 High Output engine assemblies. Technical Notes: Components in these groups are interchangeable with small-block Chevrolet V8s. GM Performance Parts distributors cannot be used with "tall deck" Bow Tie block P/N 14044808.
actual part number is 93440806, sells for about $190, i want it gone, but will not take an extremely low price, i'd like to get about $120 for it, but thats somewhat negotiable.
http://www.crateenginedepot.com/store/index.aspx
follow this link and enter the part number to see a pic, and this is where i got the description above
i also have some other parts i will be posting in the next few days, including the manifold this distributor came on. any questions post or pm
Old Nov 3, 2010 | 10:59 AM
drefi's Avatar
Re: HEI distributor
Do you still have this distributor for sale?
Old Nov 3, 2010 | 08:29 PM
Car: 92 z28
Transmission: t56
Re: HEI distributor
i still have it, the only question is whether or not i can find it because i have moved. i can look for it this weekend though
Old Dec 10, 2010 | 09:09 PM
Car: 92 z28
Transmission: t56
Re: HEI distributor
Sorry for the long delay, but i finally found it, still have any interest?
Old Jan 25, 2011 | 09:41 AM
macory's Avatar
Re: HEI distributor
Is it smallcap that will work with HSR or a standard large cap?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
