Supercharged Small Block For Sale!!
Car: 2001 VW Passat
Engine: 1.8 Turbo
Transmission: Automatic 5 speed with Tiptronic
Axle/Gears: Stock
I am selling my supercharged 360 small block. It has a K&N Xstream Air Flow Air Filter Assembly, Edelbrock 650cfm carb tuned with rods and jets, B&M 144 Roots Supercharger, ported and valve job heads with custom comp cams springs, retainers, locks, teflon seals, custom valves. The cam is a blower grind from Comp Cams, a billet timing chain set and MSD 6AL box with a Hypertech 50K coil and rotor. The block is a fourbolt main with all the block work done at NAPA machine shop. They magnifluxed, align bored, honed, bored, etc the block. The pistons are custom from JE Pistions, Hellfire Rings and Spiro locks. The rods and crank were all turned and polished. It has a summit high volume, high capacity pump built with a welded pickup for the Moroso 6 qt. deep pan with baffle. It has The waterpump is an Edelbrock pump, the engine has the chrome covers on the timing chain and valve covers. The flexplate and 8" damper are SFI approved and the whole rotating assembly was balanced out and in the motor. The motor is held together with ARP bolts. The caps on the mains are new as well. I will also include the Holley Blue Fuel pump, regulator and hoses. The radiator and cooling fans are all included too. I have the factory dual cooling fans, plus two additional fans. I have run this car in the heat of the summer with the a/c on and it never overheats. It has roughly 560hp and 470ft/lbs of torque. I have run mid 10's, low 11's on this motor before. I have pretty much all the receipts too. I have over 9 grand in the motor and am asking $7,000. Shoot me an offer and I'll see if I can work with it. There is about 4300 miles on the motor. I am selling this motor because I am moving to Colorado b/c of my job and will no longer have time or space for my Camaro.
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: Supercharged Small Block For Sale!!
any pictures?
Car: 2001 VW Passat
Engine: 1.8 Turbo
Axle/Gears: Stock
I forgot to add it has Comp Cams hydraulic lifters, hardened pushrods and raised guide plates with ARP screw in studs. I do have pictues, send me your email and I can send them to you
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
also send me pics and how much are u selling it for? just the engine or the whole car?
mynameiswhat2008@yahoo.com
thanks Kurt
thanks Kurt
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
thanks Kurt
thanks Kurt
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
