front damage 91 black firebird t-tops ,aftermarket alum 16 wheels
Old May 14, 2007 | 08:56 AM
Tallboy's Avatar
after loooking at the car it appears the front
metal is bent quite a bit ,i dont think the radiator
is damaged is but what holds it is. it was hit while parked
the motor FRAME is not bent.the 305 tbi motor has 130k on it,t-tops GLASS
no internal mods...has had msd wires ,180 thermo ,lower
temp fan switch and tranny cooler on it since 70k.it
also has alum overdrive pulleys on the water pump and
crank.also has poly anti sway bars(the one up front is
biggest you can get from factory and is hollow kind for
reduced weight but still strong).The aftermaket wheels
are a centerline aluminum 5 star pattern and were a couple hundred
a piece new.i am sure i could
get 500 for the engine and trans alone not to mention
the wheels. but will take 400 obo
Old May 14, 2007 | 10:38 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Re: front damage 91 black firebird t-tops ,aftermarket alum 16 wheels
Very interested in the t-tops. How much do you want for them? Big pin?
Old May 14, 2007 | 11:07 AM
rescuesigns21's Avatar
How much for motor and tranny minus tpi setup?
Old May 14, 2007 | 12:35 PM
Jeff89formula's Avatar
Car: 89 formula
Engine: 305 TBI
Any pics of wheels?, tire sizes?, tread remaining?. How much? Ship to Ontario, Canada?
Old May 14, 2007 | 09:44 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Old May 15, 2007 | 05:26 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
sounds like he's selling the whole car not parting it out.But if you decide to part it out interested in the TBI wiring harness
Old May 15, 2007 | 10:30 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Sent you a pm...
Old May 15, 2007 | 10:42 AM
snake70's Avatar
Car: 1979ta, 1981 formula
Engine: 400 sbc 403 olds
Transmission: th350 th400
Axle/Gears: 308 373
how far from ct are you
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
