Ported 305 Heads, Cam/Lifters and Roller Tip Rocker Arms!!
Old Jun 12, 2007 | 04:59 PM
CamMan83's Avatar
Car: 2001 VW Passat
Engine: 1.8 Turbo
Transmission: Automatic 5 speed with Tiptronic
Axle/Gears: Stock
I have a set of ported 305 heads with Z-28 high-rev springs (dual spring design) and all of the retainers for sale. The heads have been ported, had a three angle valve job and take 1.94/1.5 valve sizes. The heads flow:
Intake Exhaust
.100/64 .100/50.3
.200/126.5 .200/106.6
.300/170.5 .300/151.8
.400/202.4 .400/169.4
.500/209.6 .500/180.4
.600/214 .600/182
The heads have been used and I took the valves and valve locks to use on another set of heads for a 350. The heads are $350
I also have a Comp Cams Xtream Energy camshaft for sale. It has never been used and its matching hydraulic flat tappet lifters. The cams grind is to match with these heads. The cams specs are .470int/.480exh lift, centerline of 110 degrees, the durations are 268int/280exh. The cam and lifter combo costs $150
I also have a set of used Comp Cams Magnum roller tip rocker arms with 1.6:1 ratio. They have the center hemisphere and were used with those heads above. The set of 16 will be $100.
If you are interested in the whole combo I will make it only $550, otherwise take what you want. Please email me at cory0550@yahoo.com if interested or if you have any other questions. Thanks!
Old Jun 14, 2007 | 12:36 AM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
Re: Ported 305 Heads, Cam/Lifters and Roller Tip Rocker Arms!!
you have the cam card for the cam
whch grind number is this?
Old Jun 17, 2007 | 10:07 PM
CamMan83's Avatar
Car: 2001 VW Passat
Engine: 1.8 Turbo
Axle/Gears: Stock
I do have the card, the grind number is: CS XE268H-10
midge54
Dec 27, 2019 04:14 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
camaro71633
Sep 1, 2015 10:24 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
