Rear Koni DA's (2 sets)
Old Jul 13, 2007 | 02:10 PM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
I have a set of rear Koni DA's (the 4th gen DA's, but they bolt right onto a third gen and fit perfectly). These have about 3,000 miles on them and are in very good condition. I bought them to experiement with and don't need them.
$275 plus shipping SOLD
I've also got a set of rear DA's that have been shortened 1" on the body and 1" on the shock rod (2" shorter when fully extended). These have more mileage on them and look bad. They were working well when they came off of my 2002 Z28, but they may be leaking a slight amount of oil (or the car was, but there is some oil on them). You'll probably want to rebuild them at some point (Koni or truechoice can do the work), and you'll need the rubber mounting bushings and washers for this set (Koni should have them available).
$150 shipping SOLD
25mm rear sway bar with bushings and axle clamps (I'll include energy suspension end links, but I think they are too short to bolt on, even though energy lists them for these cars). This is a suspension techniques rear bar and has low mileage (a few hundred miles tops).
$95 plus freight
trackbird(at)columbus.rr.com
Old Jul 16, 2007 | 01:57 PM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
Re: Rear Koni DA's (2 sets)
Prices reduced.
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Aug 26, 2015 08:17 AM
kah992
Aug 19, 2015 02:55 PM
