TPI serpentine kit.
Old Jul 29, 2007 | 09:41 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
TPI serpentine kit. -sold
sold. (if I find the other piece)
Old Aug 1, 2007 | 01:25 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: TPI serpentine kit.
V belts suck, you know you want this conversion.
Old Aug 2, 2007 | 02:27 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
So much cleaner looking!
Old Aug 2, 2007 | 03:15 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I want to maintain A/C. Can I still use A/C and just eliminate the A/C delete?
Old Aug 2, 2007 | 03:28 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Yes, the compressor just goes in place of the delete pulley. if you do not want the ac delete pulley, ill knock 20 bucks off.
Old Aug 2, 2007 | 05:37 PM
wesilva's Avatar
Transmission: 200R4
I'm going from a V-belt set-up. Is it pretty obvious where things go? Do you have pics? Do I have to go to a reverse water pump? Sorry for my ignorance.
Old Aug 3, 2007 | 01:31 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I believe the water pump rotates counter clockwise, I do have a water pump if you would like it, its really new, and its the high performance one from the local auto parts house it was like 75 dollars basically just heavy duty bearings. It is obvious how it goes together. Only two brackets and the accessories fit only one spot. if you are not using a smog pump, leave it empty on the bracket and the belt I include fits perfect, with the ac compressor or with the delete pulley. Oh, I will throw in the water pump for 30 bucks.
Old Aug 3, 2007 | 05:33 PM
wesilva's Avatar
Transmission: 200R4
Have to pass for now. I'm boarding a plane in an hour and won't be back until the 12th. My job is sending me off to the "Middle of No Where" Nevada. I will PM you then. If you still have it, we'll work out the details.
Old Aug 5, 2007 | 01:28 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
It's looking like it may still be around. See ya on the 12th wesilva
Old Aug 5, 2007 | 01:02 PM
95blue350's Avatar
Car: 95 C1500 Ext. cab
Engine: 355 TPI running on the TBI ecm
Axle/Gears: 3.73 GM 10-bolt
how much with out the ac delete? the smog pump delete do yu have a pulley or are you just bypassing it? shipping to 32696?
Old Aug 5, 2007 | 01:23 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
without the pulley i will do 85 shipped. there is no smog pump delete pulley. i just did the proper belt routing. remember i am including the belt.
Old Aug 7, 2007 | 12:48 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
to the top. easy conversion!
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
Sanjay
Aug 12, 2015 03:41 PM
