Small Block 4-bolt main 350 with 327 365HP double hump heads FS
Subscribe
Sep 7, 2007 | 02:25 PM
Complete - ready to use - high performance small block chevrolet engine. 4-bolt main motor with the very desirable Corvette Double Hump High performance 365 hp Fuelie heads dated late 1964 for a 1965 Corvette. I removed this engine last november from my 1964 Corvette, 4-speed. This engine was professionally rebuilt in 1981 and has only been driven 10k since. This motor looks NEW inside, oil changes were performed every 400 miles [once per year] as it was run only in the summer months. Purchase the heads for that '65 327 Corvette that needs the correct heads or the engine for that early 70's Corvette, Camaro, Nova or Chevelle and make it correct. This motor would also be perfect for that rat rod or street drag race car as the SBC 350 with 327 double hump heads are a famous combination for lots of power.
This engine does NOT have any issues OR high oil consumption.
I had this motor in my 1964 Corvette 365hp Coupe and it ran great with lots of power.
Engine specs:
Block and heads were checked, block machined and bored .030 over (355 cu in.). Block casting number is 3970010. Pad numbers are V061TBA. June 1971.
Flat top 10:1 compression pistons. New 350 HP cam and lifters. New Z/28 high volume oil pump with new oil pump pick up. All new bearings were installed including main, rod and cam bearings, new timing chain and gear.
Heads:
1965 Corvette Double Hump HP Fuelie heads with Z28 springs, casting numbers 3782461. Date codes L24 and K304 = November 1964.
Local delivery available.
Asking only $799!
-Chris
518-928-4172
Reply 0
Sep 7, 2007 | 02:51 PM
Re: Small Block 4-bolt main 350 with 327 365HP double hump heads FS
Quote: Asking only $799!
-Chris
518-928-4172
Would you consider trades for anything?
Reply 0
Sep 7, 2007 | 06:01 PM
I might consider a trade. What do you have?
-Chris
518-928-4172
Reply 0
Sep 10, 2007 | 12:13 PM
Sale pending.
Reply 0
Subscribe
