lots of parts (ls1, 3rd gen, etc)
Old Sep 27, 2007 | 07:33 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
i have a 89-earlier camaro speedo cluster, 145 mph, speedo needle will need to be reset as it was removed and re installed. has macewan white faced overlays on it. comes with the cluster, all gages, overlays, dash bezel and clear pieces
100 shipped
also have a spohn t56 crossmember, used but in great shape, had to get a special crossmember for my swap
100 shipped
also have stock ls1 853 casting heads with valves and stock springs have 30k on them
100 plus shipping
stock ls1 1.7 roller rocker arms with bolts and retainers
100 shipped
stock ls1 lifters
60 shipped
stock ls1 pushrods
30 shipped
ls1 a/c bracket for fbody
45 shipped
ls1 t56 crossmember for 4th gen
50 shipped
stock ls1 intake, bare
50 plus shipping
stock ls1 oil pump
40 shipped
edelbrock performer ls1 carb intake setup has timing module and one pill (pills can be purchased through edelbrock and msd for cheap. NEW only bolted to engine and pulled to go fast 90 and efi instead kit costs 699 new at summit
500 plus shipping comes with bolts to install
trick flow dual valve springs rated to .600 lift, New, had to replace with higher rated springs, came on my 215 heads
200 plus shipping
manley 7.700 hardened pushrods brand new in box
100 plus shipping
stock misc camaro dash emblems (thirdgen
z28 5.0 h.o-15 shipped
z28 tuned port injection 15 shipped
z28 iroc-z red 30 shipped
z28 iroc-z yellow (1990 year rare emblem) 65 shipped
also have hooker 3 inch header collectors with flowtech cut outs 3 inch in diameter welded to them used for about 150 miles and new exhaust doesnt permit these
80 plus shipping for both
also have a autometer ultra lite oil temp guage, never used just dont need
35 shipped on that also
pbr rear disc brake setup (calipers, brackets, rotors, pads, hoses, backing plates, e brake cables. will need a ebrake lever from the dealer, cheap part)
150 plus shipping
7.5 10 bolt posi unit with 3.42 gears, would need rebuilt and maybe new gears
3 series carrier tough, and the posi does work 28 spline from a 1990 iroc
75 plus shipping
7.5 10 bolt disc brake housing with cover
50 plus local pickup shipping at full expense of buyer
28 spline 10 bolt axles from rear end above
40 plus shipping each
t56 torque arm bracket, will need bushings as i removed them
40 shipped
thirdgen t5 clutch/brake pedal assembly, will also work on lt1 t56 master cylinders, but not ls1s so i had to swap come with all brackets
50 shipped
87 carbed camaro ecm working condition
25 shipped
93 z28 yellow instrument cluster with 125k on the clock.
85 shipped
i accept paypal or postal money order prices are neg some, no lowballers please
email is streetracer420@hotmail.com in case i dont get my pms as soon as you send them
all parts will come from indianapolis indiana area
Old Sep 28, 2007 | 02:59 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
Re: lots of parts (ls1, 3rd gen, etc)
pbr brake setup sold
Old Sep 29, 2007 | 06:57 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
sale pending on the posi unit
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1nastygta
Aug 8, 2015 07:38 PM
