4th gen 10bolt rear
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
4th gen 10bolt rear
10 bolt from 94 formula
4.30 gears
broken auburn posi
ring gear spacer
welded axle tubes
moser axles 28 spline less then 500 miles, and the originals
TA cover/girddle with broken jam num and stud, works fine the way it is
spohn lcarb welded and bolted
2 callibers and rotors
i think thats everything
im in maryland and dont really want to ship it looking for $350 for it, the axles were $250 and the cover was $150 and the brackets were $60, im just trying to get back what i put in it in the last few months. i also have a spare set of 3.73 gears for an extra $50
4.30 gears
broken auburn posi
ring gear spacer
welded axle tubes
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Re: 4th gen 10bolt rear
i will sell stuff seperate, and by posi broken i only mean it has i few teeth missing from the spider gears the carrier it self is fine
Car: 91 z28 convertible
Transmission: 5 speed
IF you still have the extra set of 3.73 gears, Ill buy them for you. I can paypal or money order. My zip is 77090. thanks
Car: 89 formula
Engine: 305tpi
Transmission: t-56
yea i still have them ill check to see how much shipping is when i get home from work
AkDrifted
Aug 17, 2015 07:45 PM
