383 and 400 ci
Old Oct 29, 2007 | 07:22 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
383 and 400 ci
Selling both engines.
One is a stock 400 not bored has flat top pistons all other parts are stock other then pistons and cam rated at 465/488 lift . Make an offer. This engine was running 13 flat in my Z. Have time slip to show for it.
The 383 is 350 block 30 over TRW forged flat top pistons, 400 crank. The heads are GM phase 6 full race heads 2.05 ex and 1.60 in heads rated for 650 lift. Heads costed $759 each bare and these are complete and in great shape. The engine has Lunati Solid Roller Tappet Camshaft - Mechanical Roller Tappet - Advertised Duration 294 - 300 - Lift .597 - .600. Don't recall who made the crank or rods but if you need I will go get the part #'s. The engine is in pieces and will need put back to gether. The roller lifters are missing and the rockers are missing. This motor was set up for Nos. Will need bearings, oil pump, gaskets but all the good costly parts are their. Make a reasonable offer.
Also have Vortech Supercharger kit listed on another post.
Last edited by evoluzione1; Oct 29, 2007 at 07:23 PM. Reason: Automerged Doublepost
Old Oct 29, 2007 | 08:40 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
Re: 383 and 400 ci
how much should the 383 be running hp wise when back together?
Old Oct 30, 2007 | 12:14 PM
Engine: 400 and 350
Re: 383 and 400 ci
The engine should be around 450HP to 500HP based on the create engines Summit offers. The engine has never been dynoed.
Old Oct 30, 2007 | 04:40 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Re: 383 and 400 ci
and about how much are you looking for for the 383?? just a guesstimate.
Old Oct 30, 2007 | 07:00 PM
Engine: 400 and 350
Re: 383 and 400 ci
Around $2000, The heads alone are worth more then that to build them again.
Old Oct 30, 2007 | 08:16 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Re: 383 and 400 ci
sounds like a good price...
unfortunatly, i just bought an engine about 10 minutes ago and im going to have to stick with it for awhile.. sorry lol
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
