drop splindles
Old Nov 11, 2007 | 06:02 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
NEW drop spindles caster camber struts shocks alt water pump and more
I have a brand new set of AJE 2" drop spindles for sale I was going to use them and decided on a coilover setup instead
also a brand new set of adj caster camber plates.
Brand new shocks and struts
near mint center console top plastic from an 87 Camaro
decent shape 3 speed auto shift plate (great for th350/400 swap) this will make it look like a factory install
brand new csi billet water neck rotates 360 degrees with an O ring seal
Semi polished alternator from my old 87 Iroc everything was good when I took it apart but it has been sitting for a while I got bored and started polishing it and never really finished.
Excellent cond Adams aluminum water pump for standard rotation sbc. This is rebuildable so you could possibly use it forever. this has two extra set of ports for cooling block and heads. If you don't need them just plug them off.
assorted cv products pulleys mostly for hubbed power steering pumps and alt.
upper intake plastic from an 87 Iroc driver quality not perfect
Old Nov 11, 2007 | 07:02 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Re: drop splindles
Need to find a different host for your pictures. Says I don't have access.
Old Nov 11, 2007 | 07:08 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: drop splindles
yes i too am forbidden from seeing your parts (and i don't think you are supposed to put Ebay stuff on here. FYI)
Old Nov 11, 2007 | 07:15 PM
jstoltz's Avatar
Re: drop splindles
sorry I am just uploading on here. I am not directing anyone to go to Ebay and am not providing a link to it. I am willing to sell on here and cancel off Ebay if it wasn't for the mass exposure I wouldn't use Ebay.
Attached Thumbnails drop splindles-224850893208_0_alb.jpg   drop splindles-226030893208_0_alb.jpg   drop splindles-326850893208_0_alb.jpg
Old Nov 11, 2007 | 07:16 PM
jstoltz's Avatar
Re: drop splindles
more pics
Attached Thumbnails drop splindles-330740893208_0_alb.jpg   drop splindles-331450893208_0_alb.jpg   drop splindles-440520893208_0_alb.jpg
Old Nov 11, 2007 | 07:18 PM
jstoltz's Avatar
Re: drop splindles
more
Attached Thumbnails drop splindles-552820893208_0_alb.jpg   drop splindles-637040893208_0_alb.jpg   drop splindles-681120893208_0_alb.jpg
Old Nov 11, 2007 | 07:19 PM
jstoltz's Avatar
Re: drop splindles
last ones
Attached Thumbnails drop splindles-816340893208_0_alb.jpg   drop splindles-822430893208_0_alb.jpg   drop splindles-867530893208_0_alb.jpg
Old Nov 11, 2007 | 07:20 PM
jstoltz's Avatar
Re: drop splindles
I lied one more
Old Nov 11, 2007 | 09:02 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Re: drop splindles
how much for the camber plates shipped to a business in 30518? thanks
Old Nov 26, 2007 | 12:47 PM
capn_chaos's Avatar
Car: 83 camaro, 91 rs convertible
Engine: 94 LT1, 355 tpi
Transmission: 4L60, 700r4
Axle/Gears: 373 posi
Re: drop splindles
How much for the shocks and struts shipped to 77080? Also brand/part numbers if you have them. Thanks
Old Dec 1, 2007 | 09:32 PM
kscamaro89's Avatar
Car: 2002 MINI Cooper S
Engine: 1.6L Inline 4 Supercharged
Transmission: 6 SPD
Re: drop splindles
How much for the drop spindles shipped to 67235?
Old Dec 2, 2007 | 12:02 PM
jstoltz's Avatar
Re: drop splindles
sorry for not replying I have the caster plates and spindles on E*ay now just search for droptop383 and the shock/struts are spring tech or something like that but I would do $100 shipped on those. I can get the brand and part # if you are really interested.
Old Dec 7, 2007 | 12:16 PM
jstoltz's Avatar
Re: drop splindles
all this stuff other than the center console and water pump is still for sale. make offers.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
