complete 3:42 posi rear from 95Z NY
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
Just removed from a 95 Z28, complete end to end 3:42 posi 10 bolt disc brake rear, PBR calipers, under 10K on rebuild, has everything including rear sway bar and mounts, ebrake cables and brake hose, bolt it in and go. These work great in 3rd gens with the 4th gen wheels. $400 pick up in NY zip 12538.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: complete 3:42 posi rear from 95Z NY
Maybe this might be a dumb question but I have to ask. I am very interested in buying this as I would have to change the Gear Ratio to 3:73 anyway. I have a 1987 IROC 3rd gen, Can I still run my existing 16 Inch rims? I am just curious if it is the Axle or the PBR Brakes that makes the difference or if they are 28 spline axles can I just change and run my rims. I live upstate by Watertown, NY about 1hr north of Syracuse.
Car: way too many
The rear is 2" wider on each end so if you run your stock wheels they will be 2 inches further out. I dont need the rear, someone bring $350 and take it away
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
