355 w/ LT1 topend, BW -Madison, WI- 3.27 posi disk, 350 block, and rebuild heads
Car: 69 Olds F85
Engine: SBC 11:1 w/ aluminum topend
Transmission: Hurst commanded 4-speed
Axle/Gears: Built Chevy 12 bolt w/ 3:73s
I cashed out of thirdgens. I've got a SBC powered '69 Olds F85 now. With that said, I am open to trades for 68-72 a-body parts. Specifically looking for a Chevy 12 bolt, and a Holly 750, but will consider anything.
The 355/LT1 is out of a Trans Am I bought from Duronclocker. I was going to put it in my Olds, but am going to stick with a carburetor. This engine was running on a speed density harness/ECU. The harness went with the car, but I have the socketed ECU and an extra prom I'll throw in if I get my asking price. I don't know the mileage, but from what he told me, its low.
These are the specs he gave me:
-355ci 4-bolt 010 block bored .030" over
-Forged Speed Pro L2256 flat-top pistons, 10.5:1 CR
-GM "pink" connecting rods w/ ARP rod bolts
-Eagle cast steel crankshaft
-Ported aluminum LT1 heads modified for Gen.1 SBC ("643" castings)
-LT1 intake modified for distributor hole in rear
-CompCams XE268 flat tappet cam 224/230 duration, .477/.480 lift
Asking $1200obo
Also:
350 block with crank and rods/pistons out of a 88 Silverado $100
Rebuilt heads from a 72(ish) truck $100
Borg Warner 9 bolt axle from a 88(ish) Trans Am. Low miles, disk brakes, with e-brake cables 3.27 posi. $250obo
Complete front end w/ steering box Make Offer
I have some body parts too, but I don't think I'm allowed to post them here.
All items are right outside of Madison, WI. I really want to do pickup, but I may be able to arrange shipping at your expense.
Thank you for the space and interest
Asking $1200obo
Also:
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
Re: 355 w/ LT1 topend, BW -Madison, WI- 3.27 posi disk, 350 block, and rebuild heads
is this only trade or would u sell the 350 or TPI for cash?
Car: 69 Olds F85
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Very interested. My motor just went out. Have you done a compression leak down test on it?
Car: 92 Z28 Camaro
Axle/Gears: 373, strange axels
Do you have any horespower specs on the motor or anything? What kind of stuff are you looking for for trade? Thanks Bert!
Car: 69 Olds F85
I was told it makes about 400HP which seems about right for its specs. Looking for a Holly 750 and a Chevy 12 bolt (68-72) Chevelle/Malibu/El Camino.
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
Billy Decker
Sep 4, 2015 03:46 PM
