89 350 l98 block and heads for sale
Old Dec 9, 2007 | 12:40 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
it spun a bearing. needs a crank and a rod. well, bassically a rebuild too since it has been sitting for some time too. 200.00 picks it up in WI heads are still on it with the stock manifolds (the tuned port intake was sold already)
also have a lower tpi intake from a 88
Old Dec 12, 2007 | 06:45 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: 89 350 l98 block and heads for sale
Where in Wisc are you located? How many miles are on it? Will the cylinders clean up with a light honing or is there enough wear to require .030 pistons and machine work? Is the L98 cam and valvetrain still installed?
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
