Selling a standard bore 350ci short block, block was dissambled, cleaned with a quick hone and reassembled. 1 peice rear main seal crank standard in good shape, new main and rod bearings, stock rods and Mahle Hyperotectic flat top pistons, high vol oil pump, new Cloyes true roller timing chain and a step up from stock SLP camshaft, i think the part number is like 50001 and the profile is a 206/208 dur and something like .495 lift, its was ment to work with the stock tpi computer.
Looking to get $250 for the short block, was going in a project car, but went another direction, hasn't been fired up since reassembly.
Tony
Located in NJ 08721
Tony
Located in NJ 08721
I would be interested. Where are you located? Will you ship?
