Comp Cams CC503 NEW camshaft XE276HR
Old Jan 21, 2008 | 10:18 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Up for grabs this time: brand new Comp Cams XE276HR-14 camshaft. Commonly called the CC305. Comp part number 07-305-8. It will work with all 87 and newer small blocks, TPI, LT1, LT4.... Specs from Summit racing,
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-5,500
Intake Duration at 050 inch Lift: 220
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 220 int./230 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 290
Advertised Duration: 276 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.510 int./0.510 exh. lift
Lobe Separation (degrees): 114
Again, this cam is brand new! Check for my username in the Feedback boards, Kwik89GTA. $100 plus shipping, I'll take paypal and USPS money orders.
Thanks, Kevin
Attached Thumbnails Comp Cams CC503 NEW camshaft XE276HR-dsc00101.jpg   Comp Cams CC503 NEW camshaft XE276HR-dsc001032.jpg
Old Jan 22, 2008 | 01:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Comp Cams CC503 NEW camshaft XE276HR
PM sent
Old Jan 22, 2008 | 11:40 AM
Kwik89GTA's Avatar
All PMs replied to......
Old Jan 23, 2008 | 09:20 AM
Kwik89GTA's Avatar
SOLD!!! Thanks guys!
Kevin
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
sandman92084
Sep 12, 2015 10:27 PM
