series 3 9-bolt posi carrier..$150 shipped
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
series 3 carrier out of a 3:27 posi 9-bolt...no pinion gear(damaged thread on it..posssible to retap) ...tight..$150 shipped
Car: '88 Formula 350 & '97 VR4
Engine: L98 & 6G72
Re: series 3 9-bolt posi carrier..$150 shipped
Could you send pics of it and the damaged part to me? twizted_3kgt@yahoo.com
Forgive me for being a noob, but whats the 3-series part mean? 3.xx gear and above? And if I have a 88 formula 350, how do I know what my gear ratio is?
yes series 3 is 3:27-up....your car should have 3:27 being a formula 350...if your car is stock check the rpo code..but to be safe mark the yolk and disc and spin the yolk clockwise and count how many times it turns until the disc has come a full 360 degrees if 3 and a quarter turns it is a 3:27 if 2 and 3 quarter turns a 2:77 ect.
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
tpi-hearse... i'm looking for 3.27 with carrier..
I have a 2.77 nine bolt, 1986 t/a, 305, auto. would i need anything else to swap?
is the rear end i have a posi? is your set up posi?
thank you!
thank you!
hectre13
Aug 26, 2015 08:17 AM
Sanjay
Aug 12, 2015 03:41 PM
knight72
Aug 10, 2015 09:32 PM
