small block race parts
Car: 88 gmc 1500
Engine: 496
-new SRP forged pistons 3.75 stroke, 4.030 bore, 6" rod, flat top, two valve relief (makes a 383 with a 6" rod) pistons were assmebled in engine but never ran customer of mine decided to go with dish pistons since these will make 11:1 with a 64cc head. Pistons are like they just came out of the box. I have the spiral locks but have misplaced the oil spacer rings. I will be getting the spacer rings but buy them now for.... $325
-slightly used moroso pan #20200 7 qts, kicked out sump, 80-85 block with passenger side dip stick ...........$90
-slightly used aluminum crank adapter allows early crank to be used in late model block and can also use the early style pan above....$80
-like new stainless steel dipstick for passenger side applictaion Milodon part#22005.....$30
-new in unopened package billet timing set with torrington bearing very nice timng set made by pro-gear.....$60
-used ARP main studs for 2 bolt block with nuts and washer, good shape, ....$25
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
