coilover kit BRAND NEW!!!
Old Apr 12, 2008 | 04:58 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
COMPLETE
BRAND NEW IN BOX!
fits 82-92 style struts
AJE brand kit.
sleeves, locking nuts, aluminum top spring perch, 14" 150# suspension specialists "blue coil" springs.
i am also including strange engineering spring perch tops in this kit as well.
i believe they are better pieces, and include torrington roller bearings, where the aje ones use a teflon washer.
this kit will work with many of the aftermarket strut mounts as well, just omit the top spring perch, and the spring will ride in the aftermarket strut mount.
top perch ARE REQUIRED for being used on a stock strut mount.
kit from aje runs 239.99+shipping
$80 springs
$140 hardware
$210.00 SHIPPED. for the entire setup.
you buy a set of spohn strut mounts for 250 and you save around 150 bucks from buying the entire spohn kit.
Old Apr 12, 2008 | 10:30 PM
bygblok's Avatar
Re: coilover kit BRAND NEW!!!
TJ, what would I need to complete this in order to put it on my heap? I'm going to do that tubular crossmember and arms from Jim in a few weeks so if I can have this already together it'll make it happen quicker. Give me a shout tomorrow if you can. I'm probably headed to EC for the swap meet and to pick up my seats from Larry. Thanks, Bill
Old Apr 14, 2008 | 10:46 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i would buy a set of the spohn, or similar brand strut mounts.
the only thing that you wouldnt have from a compelte spohn kit would be some roller washers, which arent mandatory, and the reinforcement plate for underneath in the wheelwell. im sure steve could sell you a set if you got his mounts. they arent anything fancy, just plate steel cut to fit in the hole. you could do it out of some 3/16 or 1/4 stock.
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
hectre13
Aug 26, 2015 08:17 AM
