Camaro AC Delete Heater Core Box and Console Controls
Old May 12, 2008 | 01:21 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
$65 + shipping. This NON AC Heater Core Box and Control were removed from a 1983 Z28. This Box in is Very good used condition and all controls & Cables are intact and fully functional. You need to install this box if you want any control over a Non-AC Heater system as it is the vents are cable controlled.
Please post your ZIP code if your interested !
Old May 12, 2008 | 02:13 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Camaro AC Delete Heater Core Box and Console Controls
how do you take that out of the car mines broke and im lokin for ac/heat box
Old May 12, 2008 | 03:33 PM
John in RI's Avatar
You need to remove the dash housing from the firewall inside the car. Disconnect the vacuum line that controls the Heater/AC vacuum door soleniods ( if AC equiped ). Then remove the heater hoses from the heater core in the engine bay. You will also need to remove the AC blower box from the engine bay firewall. Once the AC blower Box is removed you will expose the screw that holds the interior heater core box to the firewall.
Hope that helps !
Old Sep 22, 2008 | 06:48 PM
onesweet92z's Avatar
Car: 92 camaro z28
Engine: 355 tpi
Transmission: t-5
Axle/Gears: 373
do you still have the a/c delete box if so how much shipped to 44905
Old Sep 23, 2008 | 09:56 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Also interested in AC delete box. gotta pic? wow...just looked at original post date.
Old Sep 23, 2008 | 11:07 AM
sgreen3's Avatar
Car: 1984 Z28
Engine: 355ci
Transmission: WC T-5 (untill it breaks)
Axle/Gears: 3.73 Posi
also interested 47150 if you still have it?
Old Sep 25, 2008 | 10:27 AM
John in RI's Avatar
The heater box that was advertized in this thread was sold right after the add was placed. That box is no longer available.
I do have 1 last INTERIOR HEater core box left. It was pulled from a Camaro and it needs minor repairs before it's installed.
Here are the links if you wish to view full sized images:
http://Berlinetta.info/temp/Box1.jpg
http://Berlinetta.info/temp/Box2.jpg
http://Berlinetta.info/temp/Box3.jpg
http://Berlinetta.info/temp/Box4.jpg
Here are the pics:
Description :
One cable is broken the area in question is circled in red. The clip is still attached to the vent door and the vent door operates as it should.
One vent door is rusted and should be replaced. It is "solid" (not brittle or breaking apart) other than the rusted area. It's possible the door from a AC heater system could be used - I am not sure. This area is circled in red in 2 different pictures.
The foam insulation where the floor / console vent mounts to the box is not in very good shape and should be replaced. I am sure that the foam from any box will fit just fine.
Price: $50 + shipping firm.
I have not gotten anyone shipping quotes for this box as it is not in "ready to install" condition and I would rather just get quotes for people that are still interested after they see the actual heater box that I have available and agree to the price. The heater box and the non-AC Heater control will NOT Be separated ! If anyone is still interested - just update this thread and I'll get a shipping quote for you.
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
