corvette servo for 700r4 or 4l60e f/s
Subscribe
May 12, 2008 | 03:48 PM
I have about 5 of these corvette servos in the garage. I will send it with the required seals to use it and just put it in place of your stock servo and get ready for quicker harded shifts. I build transmissions and have a ton of parts around so figured I would sell off a few cheap. 25 shipped each.
Reply 0
May 12, 2008 | 08:54 PM
Re: corvette servo for 700r4 or 4l60e f/s
Payment sent for one
Reply 0
May 12, 2008 | 09:11 PM
i'll jump on the bandwagon for one!
Reply 0
May 13, 2008 | 12:37 AM
These are new right? If so, can you hold one for me? I'll paypal in a few days.
Reply 0
May 13, 2008 | 01:09 AM
P.M. sent
Reply 0
May 13, 2008 | 05:15 AM
I'll take one. sending pm
Reply 0
May 13, 2008 | 09:52 AM
new and used. all the same. they last forever as long as no chunks pass through them. I have been building for 7 years and never replace the corvette ones due to wear. Now the others crap out quick and loose there punch but not these. I will put new rings on the servos though. Payment for one so far and let me go get all them in fornt of me before I get more payments than servos. Didnt think I would get this much of a response so quickly, which is great. will post on how many I have left in hand as I have 7 p.m.s to read through still.
Reply 0
May 13, 2008 | 11:38 AM
one sold and gone and have 4 still sitting here. One after market and 4 gm ones from 2001 to 1992. like I said really dont matter but if you have a preferance let me know.They will all work the same and give great shifts over the cheesy big one. I also have a gil yourger valve for the valve body that keeps it in overdrive at full throttle. Older ones if you are running 110+ and punch it will normally not allow a full throttle run(like a vette) in over drive. Not to hard to install. 15 bucks for it.
Reply 0
May 13, 2008 | 01:05 PM
PM me, I prefer the aftermarket Servo, also is that other part the boost valve?
Reply 0
May 14, 2008 | 10:07 AM
I'm just getting started here so sorry if this is a dumb question.
What are the effects of using one of these? Other than the harder shifting.
Like will this lower your gas mileage? Is it harder on your trans?
Reply 0
May 14, 2008 | 10:39 AM
the dumb question is o not asked. This will make the 1-2 and 2-3 shifts firmer and more positive giving a better hold making it whole shifting process more efficient. So if I was to guess not only would it not hurt fuel mileage but possibly help it a touch. They dont make it pound just firm unless it is stacked up with a shift kit in a beyond r/v mode then will hit pretty hard. It is a good upgrade to make any 700 last longer. so very good for the trans. And for the other question up there that is not hte boost valve. I do have a .500 bosst valve though around here some where and it is teh largest aftermarket one.
Reply 0
May 14, 2008 | 10:54 AM
Well it looks like this is a no brainer, I would like to check tonight when I get off work at 4:30pm to make sure I don't already have one on the car. I just bought this one a few weeks ago. will it be obvious? Also how do I pay for one, paypal, money order, etc.
Reply 0
May 14, 2008 | 01:45 PM
well you have to pop off the servo cover on the side of the trans and look at it. Can be a booger sometimes to get off. I will post a pic of what it looks like here soon. You can normally tell by the shift. Is it quick and firm or drag out a little on the one two shift. Also 3 -2 kick down will be quick with one in and lazy with the other one. If you can count to 2 between 1-2 on a normal off a light shift then most likely it doesnt have one.
Reply 0
May 14, 2008 | 02:24 PM
2 left are after market and right are gm. One top right has a shift kit spring in it with mod plate so left it in. you will have to swap that stuff from your stock one. they come with out all that stuff when new.
corvette servo for 700r4 or 4l60e f/s-car-parts-081.jpg   corvette servo for 700r4 or 4l60e f/s-car-parts-082.jpg
Reply 0
May 14, 2008 | 03:41 PM
I might as well get one its only $25, I would like the one with the shift kit spring and mod plate if you still got it. Also if I got one of the other ones what would the difference be? I guess I am basically saying that I don't know what the shift kit and mod plate do but I think I want them? If they don't make a difference I may be interested in one of the aftermarket ones if they are better, I like to use GM parts but if aftermarket is better I can do that.
Sorry I am just learning about this stuff, I know I could look through the forums to get answers but I don't want to miss out on one of these.
Reply 0
May 14, 2008 | 04:39 PM
And the order goes.....
Bump for a good guy to get these all outta here.
Reply 0
May 21, 2008 | 09:32 PM
Hey there, I need the servo and a t.v cable for a 700r4 and a filter for the same trannie. Pretty much i have a 700r4 and i just bought a tci trans-scat shift kit and so i want to do a few other things while i have the trannie out. Do you have all of the following? And how do i send a pm? do you have to be online for a pm? Thanks, Tony
Reply 0
May 22, 2008 | 12:05 PM
I have a servo left but no cable. You can get one through summit or jegs.
Reply 0
May 22, 2008 | 09:30 PM
Do you still have it? Do you have a front and rear seal for the trannie? if so how much to ship it to J3H 5G9 Canada please. Thanks, Tony
Reply 0
May 23, 2008 | 09:12 AM
still have one left and I have a set of seals too. Will run me 14 to ship it all and seals are about 5 each. So 55 for it all to you. If in the states would be cheaper.
also to pm click on my name up in the corner and it has the link there and have to be signed in to do it.
Reply 0
May 23, 2008 | 09:24 AM
I will take it if the others drop out.
Let me know!
Thanks,
Josh
Reply 0
May 23, 2008 | 09:29 AM
If you send the money it is yours. I have had a few talk and talk but no money or saying they sent money. I have enough to cover those who have said the have paid so if you want it send the money and I will ship it.
Reply 0
May 23, 2008 | 10:45 AM
please email me at yellow_eski@hotmail.com to finalize everything. Thanks, Tony
Reply 0
May 23, 2008 | 12:25 PM
Recieved my sevo yesterday looks great thanks IT1z350!
Reply 0
May 23, 2008 | 12:46 PM
wonderful.. glad I can help out some guys here. This will make a 700 live a lot longer. One of the best simple trans upgrades you can do to any of them.
Reply 0
May 23, 2008 | 09:11 PM
Payment sent.
Reply 0
May 23, 2008 | 09:16 PM
got payment for 2 of them by paypal today. If I have two money orders on the way then that is it. Let me know if you mailed one to me. I should have two on the way but no one said that they mailed it. Let me know guys so I know where I am at.
Reply 0
Subscribe
