COMPLETE GM 5.0 305 TPI Motor w/ Hdrs 5spd set up-Can HEAR RUN-60K-$450 Palmerton,PA
Old May 27, 2008 | 03:54 PM
blackphoenix's Avatar
Engine: VORTEC 350 & LT1
Transmission: T5 & T56
Hello. For sale is a 305 Tuned Port Injection Motor. It is complete w/ headers, Starter, Alternator, Radiator, Cam, Heads, Block, & Everything else for direct drop in!!! You can hear it run, before it is pulled. No knocks or major oil leaks. It has small oil leak on oil pan gasket but is an easy fix. The motor is out of a 1987 True GTA with MANUAL 5 speed set up. (M5 Transmission not for sale). The motor is not the original motor in the car. It was from an 88 GTA and has less then 60k. You can hear the motor run. Motor is very strong and has lots of life left. It comes COMPLETE with HEADERS, Roller cam, and everything else for a direct drop in (NO WIRING HARNESSES). It will need a tune up & oil change as it has not been driven daily for sometime. If you would like to hear it run, email me and we can make arrangements. No test drives! Thank you for looking. Looking to get $450 OBO. Also have for sale 700R4 Automatic Transmission w/ Overdrive, GTA Electric Window COMPLETE DOORS, & some other GTA parts.
Old May 27, 2008 | 06:15 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: COMPLETE GM 5.0 305 TPI Motor w/ Hdrs 5spd set up-Can HEAR RUN-60K-$450 Palmerton
I'm looking for some headers. If you're willing to seperate them from the engine let me know. If you have the y-pipe as well I would be interested in that too.
Old May 28, 2008 | 12:01 AM
Hello. I am currently not looking to part out motor. However, if it does not sell, I will be parting it out. Thanks for looking. goodnight.
Here is a picture of the motor.
http://i225.photobucket.com/albums/d...transam/50.jpg
Linson
Oct 24, 2025 02:00 PM
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
thejimsterz28
Sep 30, 2015 08:52 PM
Gordonr1973
Sep 29, 2015 11:59 AM
