NIB Comp Cam NX274 camshaft
Old Jun 2, 2008 | 11:49 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
I have a brand new in box Comp Cam NX274 cam from summit in the link.
http://store.summitracing.com/partde...4&autoview=sku
I went with a bigger cam and waited to long to return this one...Summit price is $126.95 before handling($10.95)
I NEED TO GET RID OF IT AND LET SOMEONE GET SOME USE OUT OF IT!
$70 shipped to the lower 48! OBO! While send pics upon request.
Part Number: CCA-12-564-4
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,400-6,500
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 244
Duration at 050 inch Lift: 230 int./244 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 292
Advertised Duration: 274 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.487 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.501 in.
Valve Lift with Factory Rocker Arm Ratio: 0.487 int./0.501 exh. lift
Lobe Separation (degrees): 113
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: CS NX274H-13
Old Jun 3, 2008 | 08:09 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Re: NIB Comp Cam NX274 camshaft
No reasonable offer refused!!!
Old Jun 6, 2008 | 10:25 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
$50 shipped!
Old Jun 6, 2008 | 09:19 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
hello, if you want to run nitrous this is the steal of the century!
Old Jun 6, 2008 | 10:37 PM
karl's-92'-z28's Avatar
Car: Too many cars
Will it work with a stock 5.0 or 5.7 TPI?
Old Jun 7, 2008 | 11:47 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Eh, it says not computer compatible on summit.
Old Jun 8, 2008 | 12:45 AM
DMX69785's Avatar
Car: 1990 Firebird
Engine: 600 hp 353.4 CI
Transmission: TH-350/B&M3000
Axle/Gears: 10 bolt 3.23
I just bought this same cam off ebay a couple days ago, damn.
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
BADMAN
Sep 9, 2015 01:54 PM
