400ci Chevy Bare small blocks in SE Wisconsin
Old Jun 9, 2008 | 11:01 AM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
I have three 400sbc bare blocks, all of them are 2-bolt blocks, two of them are bored 20 over, the other is standard and would clean up without boring if using a forged piston, otherwise it should clean up at 20 over as well. The two blocks that are already bored 20 over just need a hone, none of the blocks have been decked. one of the 20 over blocks has studs installed on the mains. They all hold water, and they are all doing nothing under my bench.
Casting Numbers:
Rust colored Block: 330817 - 2 freeze Plugs, Should clean up with a hone for forged pistons, otherwise bore over 20 over.
Orange Colored Block: 3951511 - 3 freeze plugs, Should clean up with a hone, already 20 over
Black Colored Block: 3951511 - 3 Freeze Plugs, main studs installed. Should clean up with a hone. already 20 over
$350 for the bare block with studs installed. (Black Block)
$300 each for the bare blocks without the studs installed.
Attached Thumbnails 400ci Chevy Bare small blocks in SE Wisconsin-temp-045a.jpg
Old Jun 9, 2008 | 01:11 PM
smallblockking's Avatar
Re: 400ci Chevy Bare small blocks in SE Wisconsin
interested in the 817 block.
can you call me to set up a time to look at it.
thanks
dan
Old Jun 9, 2008 | 07:43 PM
qksilver's Avatar
I am also interested in the 817 block.
One question, are the main caps marked as to location?
The other thing I would have to figure out is how to get it picked up, I live in NC.
I can do Pay Pal.........
Thanks,
Steve
Any further Pix? SCJKOVACH@AOL.COM
Old Jun 9, 2008 | 07:49 PM
ndamron's Avatar
Sorry Guys 817 block sale is pending while i await for payment, should it fall through i will let you know.
Nick
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
