350 vortec motor/complete/roller cam/4 carb
Car: 86 2wd
Axle/Gears: 2:73 open (for now)
(been awhile since i've been on here)
my plans for this motor was to run a carb, and use the intake that mounts to the vortec heads for the carb set up-
i'm selling a 350 complete engine, it was originally out of a 96 truck, i had my engine builder (very well known around here) completely rebuilt it, it only had 33k miles on it-thus why i originally bought it....
..standard bore, (had "0" wear in the cylinders),.has new rods, pistons (stock-something like 9:5:1) new GM performance roller cam (same as ram jet 350) , new timing chain/gears, new cam bearings, main bearings, new oil pump, new GM oil pan, roller lifters, new GM harmonic balancer
completely re-done vortec heads, new springs (good for 500 lift), new retainers, locks, etc...ALL parts bought from pace performance parts dot com
block came drilled for mechanical fuel pump, and the cam has the lobe for a mechanical pump as well, and has older style timing cover
comes with the hardened distributor gear for the roller cam, and new GM performance parts chrome valve covers
needs only an intake, and distributor
i have quite abit of $ in this, but i'll sell it for $1k firm
i'll try and post up some pics in the next day or so if there's any interest, i'd rather not ship, i'm in elkins west virginia, my zip is 26241
thanks
klambert@cebridge.net
thanks
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
