10pt cage and Comp stud girdles
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Jegs 10 pt cage kit. Brand new, sanctioning body wants 1 3/4", this cage is 1 5/8". $200
Comp Cams stud girdles, part number 4004, for 7/16 stud, comes with poly locks. $150
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 5.0 :( wanna go bigger
Re: 10pt cage and Comp stud girdles
Is there a way to install the roll cage w/o modifying the dash? I don't want to cut my dash up, but would like a 10pt'r. If there's a yes out there, then the next question would be will this work with a t-top car? Will I still be able to use t-tops? Or should I just think about an 8pt'r?
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
the stud girdles have dyno time only on them. they were swapped out along with the cam and rockers in favor of a solid roller and shaft mount setup
the cage would require you to modify the dash, but would allow you to use the t tops. you could make some new down bars the curve around the dash if you wanted
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
I have no way to ship it, but my brother will be driving to Pittsburgh soon for school, so maybe you could pick it up if thats not too far. its mild steel, 550-940304K is the part number. no instructions came with it
no green
Jan 9, 2016 09:22 PM
tmork454
Sep 29, 2015 06:33 PM
