TPI Parts
Old Nov 13, 2008 | 08:42 PM
otecnick88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350 .060 over carbed
Transmission: TH-700R4 w/2800 stall
Axle/Gears: 9 bolt w/3.27s till it breaks
TPI Parts
i have some parts off a Firebird Trans Am GTA
Edelbrock High Flow TPI Base - $200
TPI runners, stock, no 9th injector, off 89 GTA - $100
TPI runners, stock, has 9th injector, 88 GTA - $100
Fuel Rail with Accel adjustible FPR, and 24lbs injectors, no 9th injector - $300
Upper Plenum from 88 - $50
Upper Plenum from 89 - $50
Throttle body from 88 (has NEW IAC and TPS) - $100
Throttle Body form 89 (has IAC and TPS) - $75
MSD Coil, lightly used - $30
2 Distubitors from 88 & 89 - $50 a peice
MAF from 88 - $100
TB to MAF intake tube - $50
MAF to Filter intake tube - $50
Stock Air filter box - $50
Specter High Flow Wire Mesh and Cotton filter, fairly new - $25
SLP Throttle body Airfoil - $30
shoot me offers and we can talk from there im not shure how much everything goes for so, i have/can get pictures of everthing else if needed, these pictures were taken with a camera phone so sorry about the clarity, request for pictures in pms and specify what part you want
Old Nov 14, 2008 | 09:01 AM
Isphius's Avatar
Car: 84 sport coupe
Engine: stock lg4
Axle/Gears: stock?
Re: TPI Parts
is the 89 distributor the same as 91? im not entirely sure. If so ill take it!
Old Nov 14, 2008 | 08:00 PM
Re: TPI Parts
[quote=Isphius;3948330]is the 89 distributor the same as 91? im not entirely sure. If so ill take it![/quo
if its TPI then ya its the same, pm me your zip code so i can give you a shipping quote
Caspar
Jun 19, 2016 11:19 PM
masonta
Aug 31, 2015 10:14 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
