89 formula 350 parts or whole
Car: 89 formula
Engine: 5.7
tpis miniram
zz409 cam
afr/tpis alum heads
tci streetfighter tans
2300 stall tci converter
march undedrive pulleys
compo cams 1.6 roller rockers
msd distributor and coil
2004 corvette wheels
4th gen rear with brand new 3.73's
alpine cd player
other stuff i may have forgotten, just ask for specifics
slp headers and cat back 2 on the left
svo #24 injectors
optima battery
headlight motors work
t-top
located in baton rouge, la.
zz409 cam
afr/tpis alum heads
alpine cd player
svo #24 injectors
optima battery
t-top
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: 89 formula 350 parts or whole
Price, and info On:
Thanks!
Thanks!
Car: 1986 camaro
Engine: 406ci
Transmission: th400
Axle/Gears: 3.55
tpis miniram
zz409 cam
afr/tpis alum heads
alpine cd player
svo #24 injectors
optima battery
t-top
zz409 cam
afr/tpis alum heads
alpine cd player
svo #24 injectors
optima battery
t-top
Car: 89 formula
Engine: 5.7
250 for the mint alpine cd player. what info do u want of the comp cams rollers, coil and dist. 350 for them all. two pipes out of one muffler on the drivers side, very common on these boards.
Car: 1986 camaro
Engine: 406ci
Transmission: th400
Axle/Gears: 3.55
Got pics or links or part #'s on the coil and dizzy? Im trying to build a 383, and when it comes to ignition, i have no clue.
THanks
THanks
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
t tops shipped to 23227?
