350 4-Bolt std bore 2pc crate motor
This engine was purchased new (Goodwrench), ran 19,000 miles in van. Block 10066036 with 993 heads (1.94, 1.50). Heads, oil-pan removed. Short-block untouched. Super clean when Inspected. Timing set, cam and lifters can be used; in great shape. Times are tuff. Bought 82 Camaro with promise of title and it hasn't materized. Have all parts for this engine (brackets, Q-jet cast iron intake, w/pump, alternator, starter, HEI distrributor, manifolds). Have new in box: Jegs 12" converter (#60400, 2300-2700) for TH350, Comp Cams XE274H (CL12-246-3) and lifters, Jegs #20412 timing set, Jegs #7100 gasket set, Mr. Gasket curve kit, and Holley Street Dominator (open plenum) intake. Q-jet also, but needs rebuilt. Also TH350 long-shaft trans. $700 takes all. Illinois pick-up preferred (Hillsboro, 62089) Call 217-851-2036
Last edited by robjuicer; Nov 29, 2008 at 08:58 AM. Reason: to include phone number
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
