406 rotating assembly
Old Dec 21, 2008 | 01:30 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
I have a good used 406 rotating assembly for sale. It consists of a stock 400 crank that was recently turned so the mains are cut 10 thousands. The rods are all marked and shotpeaned. The pistons are just regular flat top 30 over for a 400. The assembly was balanced and run in the motor for about 6000 miles. I'm replacing it with a full forged one because I want higher RPMs and to run a nitrous kit. I'm asking 350 for everything. I have pictures but the files are too large to upload. So just post or PM me an e-mail address.
Old Dec 21, 2008 | 05:35 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: 406 rotating assembly
can you send me pics my email address is jasontejada@yahoo.com
Old Dec 22, 2008 | 11:27 PM
WIll36's Avatar
Engine: 355, 408
bump
Old Dec 23, 2008 | 01:33 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Was this balanced with flywheel and damper,what length rods?
Old Dec 23, 2008 | 06:48 PM
WIll36's Avatar
Engine: 355, 408
The assembly was balanced with a flexplate and damper. I already sold the flexplate and still have the damper, but I think it's the original unit so it's 30+ years old.
Old Dec 27, 2008 | 11:28 PM
WIll36's Avatar
Engine: 355, 408
bump
Old Jan 6, 2009 | 08:05 PM
WIll36's Avatar
Engine: 355, 408
bump...make an offer
Old Jan 6, 2009 | 11:58 PM
apache3132's Avatar
406 are external balanced. The flywheel or flexplate and the front damper are part of the balance. If you change any of them it is no longer a balanced assy. just a note for clarification.
Old Jan 7, 2009 | 01:04 AM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Hey will so after you sell this you think your going to send me some money to make that trade between us right? Seeing as u gave me a 273 rear instead of a 323??
Old Jan 7, 2009 | 11:55 AM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Although the weight on the flywheel is part of the balance,Most people that balance engines leave the external balance on the flywheel the same as stock,, and add or remove weight from the crank, this way if you damage either the balancer or flywheel,you can readily replace them rather than have to rebalance a motor due to a chipped flywheel tooth!
Old Jan 7, 2009 | 05:51 PM
WIll36's Avatar
Engine: 355, 408
I've asked you 3 times to meet up with me and take your rims and spacers back and give me my axle and console in return. This even after you make the mistake of thinking that I'm a fool and you could scare me by threatening to call a lawyer. Then again I noticed you already put the rear up for sale in a thread that said you were getting rid of everything to join the armed services. Which contradicts everything you told me. So let me make it very clear, I have no intention of sending you any form of payment. So for the 4th time I will ask you if you would like to meet up and swap parts back if you really think you didn't get a fair deal. You have my phone number, email and can PM me and chose not to for the past week after I made it clear I will not give you any money as part of this deal. Now grow up and conduct business according to the rules of this forum. I very well could have put a bunch of junk posts like this on your threads, but chose not to. If you keep posting junk like this I'm going to contact the moderators to correct this.
You are correct on a stock rotating assembly the motor is externally balanced. It was an oversight on my part to put that in the initial post.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
Dragonsys
Sep 25, 2015 03:51 PM
