New 383 sbc
Old Dec 25, 2008 | 08:43 PM
kickass92z's Avatar
Car: 92 Z28/86 T/A/98 R/A T/A
Engine: 355,355,LS1
Transmission: T-56,700r4,T-56
Axle/Gears: 3:73,3:42,3:42
New 383 sbc
Here is a list on the engine it is a 92 L-98 block that is the only thing used. The engine was in a 92 camaro, with a Holley Stealth ram, it requred more tuning than I wanted to do, so it literally has only been around the block 1 time.
Block was done by Tuckers Machine in Murray Ky.
Bored .030 clearenced for crank
Heads are Aluminum Patriot 2.02 1.60 valves, 64cc combustion chamber, valve springs good for up to .600 lift, angle plugs, 7/16 studs, Heads have been cnc ported, 1.6 roller rockers, hardened push rods, new roller lifters, hardened head bolts
Rotating assembly
Eagle Crank, H-beam rods, SRP coated skirt pistons, everything has been fully balanced
Cam is a Comp Cams XR276HR-12 ( e-503) Lift I believe is around .590
new Mellings oil pump
new roller timing chain
new water pump
Fabricated valve covers, notched for alternator
Engine was assembled by Mitch Leidecker at Leidecker Automotive in Ledbetter Ky. It is 9.7 compression
Any questions call 270-210-4922 asking $3300.00
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
