[VA] Roller Cam 230/236
Car: 1992 Formula 350
Engine: 5.7 L98
Roller Cam 230/236
I am selling a Will Hoites Cam same cam as: Comp Cam XR282HR-10
Part Number 08-432-8
Grind Number CS XR282HR-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.51 0.52
Duration At 0.006 Tappet Lift 282 288
Valve Timing At 0.006
Open Close
Intake 35 67
Exhaust 78 30
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 230 236
Lobe Lift 0.34 0.347
Lobe Separation 110
Recommended Valve Springs 986-16
Cam is brand new never used. $130.00 shipped. Thanks.
Description
Intake Exhaust
Open Close
Intake 35 67
Exhaust 78 30
Intake Exhaust
Lobe Separation 110
Engine: 5.7 L98
Re: Roller Cam 230/236
It is a roller cam for the late model blocks. Not sure about the fuel pump lobe. I use to live in PA near Stroudsburg.
