5 spd set up for sale
Old May 1, 2009 | 07:05 PM
dpmalibu's Avatar
Up for sale is the 5spd set up that is currently in my car. I want to switch over to automatic. There is nothing wrong with any of the parts just tired of driving stick in a town with way too many lights, plus I would rather the car be more consistent at thetrack with an automatic anyway. i have never raced the car at the track yet so it have not been beat on. The trans is a W/C T-5 with a Hurst shifter.It has about 87,000miles on it. The clutch is a made by RAM ( I beileve stock replacement) w/ about 2000-2200 miles on it, the fly wheel is a Hayes billet steel flywheel w / about 1000-1200 miles on it. You will get the trans,flywheel ,bellhousing, shifter, pedal assembly and the clutch master cylinder and the crossmember. Asking $600 B/O . I would prefer local pick up or possibly meet you somewhere local. Shipping would probably be more of a PITA than its worth .
Not looking to split up any parts as of yet would like to sell the whole set up. Located in Hatboro ,PA (10 min outside of NE Philly).
Everything is still in the car so you can test drive before i pull it out.
Old May 1, 2009 | 08:04 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: 5 spd set up for sale
i have a 700r4 i'll swap you if it is a v8..would have to be shipped though..i'm in louisiana
Old May 2, 2009 | 06:38 AM
dpmalibu's Avatar
No thanks.
Old May 3, 2009 | 10:39 AM
dpmalibu's Avatar
Price is not firm. Make me an offer.
Old May 3, 2009 | 01:32 PM
redz281986's Avatar
Want a title? Post!
Is the trans still available thanks i can pick it up
Old May 3, 2009 | 03:08 PM
dpmalibu's Avatar
I still have it. it's still in the car.
Old May 4, 2009 | 02:41 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
location
Old May 4, 2009 | 02:50 PM
dpmalibu's Avatar
Hatboro,PA
Old May 4, 2009 | 04:01 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
is this a TBI or TPI one? (5th gear: 0.63 vs. 0.74)
Old May 4, 2009 | 04:03 PM
dpmalibu's Avatar
I have no idea.
Old May 5, 2009 | 09:42 AM
ownor's Avatar
Engine: LS1 / L03
you could do the following test to examine 5th gear:
turn the input/flywheel side of the transmission and observe how much input side revolutions you need for one output side revolution.
if it's over one and a half rev (exactely 1.58 revs) you have a 0.63 5th gear (TBI T5), under one and a half (1.33 revs) it's a 0.74 5th (TPI)
Old May 5, 2009 | 10:05 AM
dpmalibu's Avatar
I am 95% sure it came out of a TPI car. I am trying to find out from the previous owner.
Old May 7, 2009 | 07:27 PM
dpmalibu's Avatar
ttt
Old May 10, 2009 | 05:40 AM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
I really need that T5 tranny like yesterday (out of a V8, correct?). I don't need any of the other parts however. If you get to the point where you would be willing to part it out, name a price for just the transmission and pm me. Thanks.
Old May 10, 2009 | 08:04 AM
randy111's Avatar
Car: 1991 Camaro RS vert.
Engine: 305 TBI
Transmission: 700R4 Auto
If your willing to split sale, I'm looking for parts plasmeh is not needing most likely. I need peddals, master, slave fluid resivor and the clutch hose for the cylinders. I'd gladly purchase them I have a T-5/V8 setup jsut wating to go into my car. Need these parts to finish up the install. PM if interited. thanks.
-Randy-
Old May 13, 2009 | 05:55 PM
dpmalibu's Avatar
Randy111 Pm sent
Old May 16, 2009 | 11:57 AM
DonsL69's Avatar
Want a title? Post!
Car: 1984 Z28 L69
Engine: 5.0
Transmission: M5
Would you happen to have the original shifter? I am looking for the original leather shift **** that was stitched like a baseball for my 84 z28. Thanks
dkersh2@verizon.net
Old May 16, 2009 | 12:08 PM
dpmalibu's Avatar
No I don't have the original shifter
Old May 18, 2009 | 02:48 PM
dpmalibu's Avatar
Sold!!!
I do have the flywheel and pedals left.
colton_carlson
Mar 8, 2019 12:21 PM
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
cam-mike
Aug 24, 2015 07:23 AM
